Hello All, I have a concrete seat wall that will not show a surface pattern. I have made sure the material of the wall is set to show concrete as the foreground surface pattern. I have also made sure the phase was not overriding to show something else. I have checked the visibility/graphic overrides and reset all to be "<By Material>". I have checked my view range to be sure it was below the cut plane. I have set the detail level of the view to "Fine". I am not sure what else could be causing my concrete seat wall to show as solid white. Any thoughts on how to get the surface pattern to show in plan would be great. Thank you!
