Surface pattern of concrete seat wall not showing in plan.
lance.hinkle
lance.hinkle
Hello All, I have a concrete seat wall that will not show a surface pattern. I have made sure the material of the wall is set to show concrete as the foreground surface pattern. I have also made sure the phase was not overriding to show something else. I have checked the visibility/graphic overrides and reset all to be "<By Material>". I have checked my view range to be sure it was below the cut plane. I have set the detail level of the view to "Fine". I am not sure what else could be causing my concrete seat wall to show as solid white. Any thoughts on how to get the surface pattern to show in plan would be great. Thank you!
Wall material surface pattern does not show for top and bottom.  There are several ways:
- Paint the top of the wall with Concrete material.
- Create parts from the wall
- Edit Wall assembly, modify regions in section view to create a top wrap (may not work if you only have one layer)
