Surface Pattern not Displaying
BigPicture045
Message 1 of 9
BigPicture045
I need these to display with a concrete surface pattern:
No View Template used in this view.
You can see that the elevation view is not cutting, but should be showing the surface of the elements:
You can see the 3D view does not show concrete on the sides:
These are system floor families:
Replies (8)
Message 2 of 9
Paint the wall and floor edges with the concrete material.
Message 3 of 9
BigPicture045
@ToanDN
Is this normal for floors not to display the pattern on its sides?
Message 4 of 9
@BigPicture045 wrote:
@ToanDN
Yes.  The edges are defined not by the components' materials, but via Object styles.
Message 5 of 9
hmunsell
not that you would necessarily want to.... but you could select the element and pick Create Parts too.
Howard Munsell
Message 6 of 9
BigPicture045
@hmunsell What does this do and why do you suggest this?
Message 7 of 9
hmunsell
it breaks the element down to its individual components. so a wall or floor  that has multiple layers in its structure will separate out into there layers and can be manipulated separately.  i only use them in very specific instances. i have just seen it cause issues in a model when it is done too often.
on the left is a wall that has had Create Parts applied to it, on the Right is a normal wall.
https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-DA150C6B-996C-4C70-9E8C-3C536C232851
Howard Munsell
Message 8 of 9
Select Floor and press Create Parts and watch the magic happen.
Message 9 of 9
hmunsell
you can control the visibility per view with the Parts Visibility properties option....
Howard Munsell
