Surface pattern(model) not rotating
onplandesign
Message 1 of 9
onplandesign
I'm using 2022 Revit and cannot rotate any of the model surface patterns. I have tried a number of different materials all with model fill patterns and cannot rotate any of them. Have checked that they are all model fill patterns. Also update to latest hotfix.
Replies (8)
Message 2 of 9
syman2000
Is your surface has curvature? If yes, you won't be able to rotate it.
Message 3 of 9
Message 4 of 9
RDAOU
@onplandesign
Model Patterns on Conical and Cylindrical forms with circular base cannot be rotated...for these you will need a custom pattern rotated in the .pat or you have to resort to other means in modeling the elements
On all other forms, flat or curved you should not be having any issues...
Message 5 of 9
onplandesign
Thanks for your help.
Message 6 of 9
TOURNLAU
i have the same problem, and have already tried everything.
Both on floor and walls this does not work.
What else can I do?
Message 7 of 9
matthewBMAYG
Try unticking the 'copy' option on the rotate tool - this was stopping me from rotating surface patterns.
Message 8 of 9
Ryan_FordStudio
WORKS! THANK YOU!
Message 9 of 9
troy_troy
This was my issue. Thanks!
