Surface pattern graphic, it don't change in layers of basic wall
user02gsch
user02gsch
Hi, my issue is that the light blue and green wall layers are different in material and surface pattern, but the graphic surface appears like the same. Apparently the pattern shown is from the opposite face layer, but I need the middle layer material to appear. I hope you can help me. thanks.
noah_AvatarMetaverse
I think you should change Material in Foreground in surface pattern, not only in cut panel
