Surface Area
Surface Area
LanggamanXavierMassed
Message 1 of 13
Surface Area
is there any way you can actually modify a floor or any surface where an input area cannot be changed? that would be so cool.
like, if you adjust a side of a floor or a wall's width, the length adjust to maintain a given area.
Replies (12)
Message 2 of 13
dferreira-blackwell
could be possible, but not by Revit itself, maybe using dynamo it could be achieved.
Message 3 of 13
so, what your are saying is that if one side of a 100 sq. ft. polygon-shaped floor was moved, the other sides (however many there are) would move as well to maintain 100 sq. ft. ???
Sounds like a nightmare.   I'm probably misreading you.
Message 4 of 13
constantin.stroescu
I think that you will be able to do it by using:
  • Global Parameters with Formula - that for System Families like Floors, Walls.
  • For Editable Families , use simple Parameters with Formula...
In my example I did it for a Floor:
https://knowledge.autodesk.com/community/screencast/8a178412-2038-4125-a542-0b5bef5601c0
Constantin Stroescu
Message 5 of 13
How about this one, @constantin.stroescu ?  Smiley Wink
Message 6 of 13
constantin.stroescu
If I understood well LanggamanXavierMassed  he looks  for shop drawings , shop drawings for prefab elements .At least , I use these for such purposes .
Anyway when I have make such prefab structures I made them by putting together simple rectangular components , like shown below:
  like Henry Ford said:
"Nothing is particularly hard if you divide it into small jobs."
Constantin Stroescu
Message 7 of 13
that's exactly what i meant
Message 8 of 13
thank you sir
Message 9 of 13
So you want a "pushmi-pullyu" floor.
Message 10 of 13
but i don't get why put *1m^2, after the inconsistent unit warning, but btw this is really good
Message 11 of 13
yes but in some cases only when the area is a heavy concern.
Message 12 of 13
Why I had to use *1m2?
  • When I chose A_Check  Global Parameter , I had not the option of area , but I had the option Number (have a look at the screencast )
  • Number has no units (it's abstract) - so ,as long as I use it as an Area Value, Revit expects the Area to be in square meters - that's why I multiplied with 1 unit of Area...
Constantin Stroescu
Message 13 of 13
oh i see, thank you for this it's very clear,  i'm learning a lot, this is great.
