Suite work flow revit 2017 to max 2017
t_darcy
t_darcy
Hi I m using the suite work flow to take my revit model in to max but no matter how I try the combine objects by material will not work .....is this a known issue ?
Viveka_CD
Hi @t_darcy
When you combine by By Revit Material, All objects that share the same material should become a single 3ds Max Design object. For example, all Revit objects with the glass material become one 3ds Max Design object.
Can you try limiting the geometry that is exported to 3dsMax and see if that helps.
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
t_darcy
As stated in my first post above the combine by materials does not work....bringing in half my model is not an acceptable solution....this software cost thousands of pounds, it has an option to combine by material which does not work and workarounds are not acceptable.
Also i see there is still problems printing large jobs to pdf and revit seems incapable of handling a large number of RPC's in one scene in realistic view mode.
If this software was a high street consumer item i would ask for my money back.
Viveka_CD
Hi @t_darcy
Can you share a file to test? I can send you a private folder.
Looking forward to your reply.
