Stucco Exterior Finish
PhilvK
Advisor Advisor
Message 1 of 15
PhilvK
I don’t see an exterior wall finish for stucco in the Materials area of the Edit Assembly window. Is there some way to download it, or is there a quick way to create a new material similar to editing a Family Type?
Phil
Replies (14)
Message 2 of 15
L.Maas
Revit (2015) has stucco in its material library.
You can load the material into the project and assign it to a layer of the wall.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 15
PhilvK
Thank you! I found it and dragged into the list above as you show in your screenshot. Is that the correct method to "load" it into the project?
Phil
Message 4 of 15
L.Maas
Yes, drag or double click is Ok.
Louis
Message 5 of 15
guiracochab123
WHAT PATTERN COULD I USE WHEN MAKING A STUCCO WALL? LIKE WHAT BACKGROUND PATTERN OR FOREGROUND PATTERN?
Message 6 of 15
guiracochab123
Message 7 of 15
PhilvK
'Sand' works good for foreground. I don't use a background, but you could use a light gray or tan solid for background if wanted to.
Message 8 of 15
guiracochab123
THANK YOU VERY MUCH. WHAT ABOUT THE STURCTURE OF THE WALL? IS THIS FINE?
Message 9 of 15
PhilvK
Your wall structure is fine as long as what you show is adequate for the design constraints and locale.
Opinion only: I would normally use thicker plywood or dens glass board for the sheathing , but that's your call.
Minor: Check your spelling for BUILDING PAPER
Message 10 of 15
guiracochab123
HOW THICK WOULD YOU WANT ME TO MAKE THE PLYWOOD SHEETING? AND I DID FIX THE TYPO LOL THANKS FOR TELLING ME
Message 11 of 15
PhilvK
Not sure if talking about specific components with respect to wall design is in line with forum etiquette, but I always use 5/8" dens glass under stucco assemblies (unless on cmu), and that's for commercial construction. I'm sure others will have different opinions, especially if this if residential. My answer is also not knowing anything about winds loads, budget, etc., etc.
Message 12 of 15
guiracochab123
THIS IS FOR A PROJECT FOR MY CLASS. I JUST WANT TO KNOW IF ITS THE THICKNESS IS RIGHT. IM A LITTLE CONFUSED ON WHAT U MEAN BY DENS GLASS UNDER THE STUCCO. THIS IS GOING TO BE A RESIDENTIAL BUIDLING.
Message 13 of 15
PhilvK
Dens glass is an exterior sheathing board that can be used in lieu of plywood. For your class project I would use that or 1/2" exterior grade plywood. 3/8" is too flimsy.
Message 14 of 15
It is not a Revit question.  Do a google search for exterior stucco wall construction so you can find out what are needed.
As a quick glance, I agree with @PhilvK on using dens glass sheathing in lieu of 3/8" plywood.  It also depends on structure, you may need shear panels then you need to add plywood or sheet metal to the assembly.
Message 15 of 15
guiracochab123
Alright I’ll definitely do that. Thank very much for ur help, I really
appreciate.
