Stucco Construction joints drawn with model llines do not show when rendering
octavio2
Message 1 of 22
octavio2
The stucco construction joints drawn with model lines on the exterior elevations (to show scoring when the wall is very large) do  show in the elevations and in the 3D model, but when the model is rendered using one of the rendering methods in the cube on the left lower  corner of the Revit window (shaded, realistic, etc.) , these lines to show the scoring do not show.   The rendering is basically OK, but I wonder why these lines do not show on the rendered model.  I thought that when we use model lines (against detail lines) the lines have to show in the model.
Any advise or feedback a out this?
Thanks in advance.
Replies (21)
Message 2 of 22
L.Maas
They are visible in the model. However when rendered they will not show. You can think of it as this, model lines have no material an no depth and thus renderer will not be able to render it.
If you need to show separation in the renderer you will need to create this. This can be done to make use of a small extrusion. Depending on the type of renders you make this could be a small solid extrusion or a small void extrusion. Otherwise you have to create small gaps in other ways.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 22
Vertical Wall Reveal
Message 4 of 22
Model lines have no surface or volume so they cannot show in a rendering.  Use wall reveals or a line based family for hor/ver straight lines, or an adaptive family for complex curves.
Message 5 of 22
octavio2
Will like to see suggestion on ways on how to add the scoring to the Revit drawing that will show on the rendering.  The attached rendering do not show the scoring that is seen when a PDF is created.
How to add the voids?
Thanks in advance.
Message 6 of 22
Avaris.
Would recommend to solve this issue within the texture. It makes no sense to model a very detailed pattern on your surface.
Message 7 of 22
octavio2
The "Wall Reveal" "Default" profile seems to work, but it is too BIG.  the reveals that the wall have are something like 1/2" x 1/2".  How or where do we make that "Default" reveal smaller? (it is parametric?).
Message 8 of 22
Avaris.
Create a new profile. New family > Profile-reveal > draw whatever you want. Load it into your project.
Then edit the type, (duplicate one) and change the profile here to what you drew before.
Message 9 of 22
Here.
Load this 1/2" x 1/2" Profile Family into your Project and assign it to a "Reveal" System Family.
Message 10 of 22
octavio2
Thanks, it seems to work.
Might have to figure out a way to paint the interior black or another darker color.
Reveals  being so common in architecture, I wonder why the default "wall reveal" cannot be made parametric so we could change the dimensions on the spot without so much hassle.
Interesting subject, thought.
Message 11 of 22
So, basically what you are saying is that you want a "reveal" which can be sized per Instance -- not per Type.  Well then, create a Line-Based Family that pulls a void cut, and create Instance Parameters to control each instance's depth and height.
BTW: you can paint the interior faces of the reveal black by using the Paint Tool.
...you know, that when Thin Lines are turned off, that 1/2" x 1/2" reveal may just look like one thick line.  Wall Reveals use the Wall Projection/Cut Lines Weights.
Message 12 of 22
octavio2
The paint is done in the family editor or in the model?
Where is the paint tool?
Message 13 of 22
In the family editor??? The family is a profile -- not geometry. Do you look at what I posted?  You paint the faces of the reveal geometry that is created from the profile.  The Paint tool is located on the Modify Tab of the Project.
Message 14 of 22
octavio2
The paint tool is not working in the reveal, not even when I used the split surface tool.
Message 15 of 22
Avaris.
You need to use the tab-key in order to select the inside of the reveals.
Message 16 of 22
I have no issues.  Are you actually selecting a FACE of the reveal geometry? In your case; a 1/2" x 1/2" reveal should have 3 separate faces. Each will accept Paint.
Message 17 of 22
octavio2
Continuing with my rendering education, I have the following issue: I have now the problem with the west wall, which is existing brick, to be painted of the color shown, but has some undesired reflections, which I believe are not sun or shade reflections.  It is the short wall where the window is.
Any idea of how to get rid of these diagonal reflections?  Or what cause these?
Thanks in advance.
Message 18 of 22
Post the file so we don't have to guess.
Message 19 of 22
octavio2
The rendering where the reflections are shown is attached in the same posting where the question about these undesired reflections was made. The reflections are on the short wall on the left, where the window is.  They look like diagonals emanating from the window opening there.  Thanks.
Message 20 of 22
I don't know where that is.  Can you direct me?
