structure rebar shape image
husamcivil
husamcivil
Hi all
I have revit 2019 when I used re bar scheduled I go to content family folders but I found structure rebar shape (images) empty
so how can I get it
thank you all
Are you saying the Thumbnail is not showing anything?  Do a Save-as, click on Options and change the Thumbnail View.
Corsten.Au
Place the Rebar schedule on Sheet..
If the shape is still not visible, then you may need to manually update it using
appropriate JPG, PNG image...
I would suggest to look up and reverse engineer the working schedule / file where rebar shape
is shown...
Best luck.
Corsten
Building Designer
Are you taking about the Rebar Shape Browser that can be activated via the Options Bar? You mean you have no shapes shown there? Are they loaded?
husamcivil
thank you for your answer but I don't mean this shape ,I mean the images used for schedule
Rebar Shape Families with Shape Images according to BS8666:2005 :
https://www.dropbox.com/s/o8e1668vdwcybmp/20161215%20-%20Rebar%20Shapes%20in%20Revit%20-%20Shape%20F...
