Structure offset on Rex
I have problems using Rex, when structuring with wood, the elements are not in line with the wall. I open a new file and it doesn't present the problem. I cannot find the configuration that I must have modified in the file.
Thanks for the help.
Wall Justification is honored from what I remember of the Extension.
,,,your screenshot is an Elevation. What are you talking about?
Hi Barth.
The capture is from an elevation. The problem is that the wooden structure is out of phase with the wall (blue color). It is run to the right and down.
Unfortunately I cannot replicate at my end. Post your file.
There goes the file... Thanks
