Structural Grid Lines
dsalvagni
dsalvagni
In the office that I work at they like the structural grids to have a gap so they do not go through the plan, but on the elevations they like the grid lines to go through the elevations without a gap, is there a way to achieve this?
jay_colc
You can create a new Style for the Gap Option and Apply it to Plans and use this as the Default Grid Line Style for the elevations.
Select the Grid line > Properties Palette > Edit Type
Duplicate the Existing Style
Change the setting for “Center Segment” to “None”.
Change the ‘End Segments Length’ to a different value if desired.
You can override any individual grid lines via grips on the screen.
Jay Colcombe
Autodesk Certified Instructor
Alfredo_Medina
@jay_colc  How do you change the type of a grid line in one view without changing the same grid line in another view?
jay_colc
Good question @Alfredo_Medina, it would have to be a manual process of dragging the node point of one of the ends down to the other segment
Maybe a compromise would be to display the centre segment in a lighter colour to try and please both scenarios?
Jay Colcombe
Alfredo_Medina
OK. In your previous post you used the word "style" and then gave instructions about how to duplicate the grid type, and then you said that the user could apply one "style" to plan views and another one for elevations. So, by "style", you meant just manual modification of the grids, not in the sense of "type".
jay_colc
Yes, apologies for the confusion.
Jay Colcombe
