structural framing family cut pattern interacting with wall in section
jledgewood409
Message 1 of 10
jledgewood409
i have all my structural framing family material cut pattern the same (dark gray). my wall patterns are set to a light gray. when the two interact the wall seems to take precedence. how do i get the structural framing family to be the dominate item in the section? attached are PDF's of examples for the above.
Replies (9)
Message 2 of 10
Reverse join order
Message 3 of 10
jledgewood409
when I select the join or join order tool button I am unable to select the structural framing member.
Message 4 of 10
Switch Join Order then select the Wall.
Message 5 of 10
Message 6 of 10
jledgewood409
still having trouble with the join/ switch join. I selected the switch join then selected the wall. I am still unable to select the structural framing member (family). I am attaching a file that has my condition for a better understanding. I have cut a section through the condition so you can see what I am describing.
Message 7 of 10
See attached.
Edit the beam family and set the 3D geometry to be visible for all detail levels: Coarse, Medium, Fine, then you will be able to join them with the wall.
Message 8 of 10
jledgewood409
so this technique has worked for the most part. thank you. i am having some issues when i apply this technique to beams and walls in sections. i get the beam to show through but the outer/boundary line of the beam disappears. i am including a screen shot of what i am describing.
Message 9 of 10
Do you have Overrides in that view?
Message 10 of 10
jledgewood409
no override in the structural framing for the cut line or cut pattern
