Structural foundations material not showing in Section
cbt990
cbt990
Created Structural foundations in place and assigned them all concrete. Unlike a wall element, the hatch pattern here doesn't seem to show in section. I need to be able to see the hatch so that it appears correctly when linked into a central file.
Revit is amazing
alan.johnson7YLND
Have you checked the cut pattern for your material
Why is it an in place model family and not a system family?  Did you edit the in place family and assign the material to the extrusion?
cbt990
I created it by modeling in-place, because this seemed like the best workflow for allowing me to adjust the footing depths later.
Revit is amazing
