STRUCTURAL ELEMENTS DISAPPEAR IN 3D VIEW
Good afternoon!
In the model i have been working on, the structural elements whereas the columns and slabs disappear when it comes into 3D view.  In 2D everything seams ok and is in its right placement, in all plans, sections and elevations.
Have checked visibility & graphics menu already but everything seems to be visible.  Also, nothing seems to be hidden in view.  In previous model of the same project alla structural elements seem to be right.
Please get back to me with ideas or possible solution.
Hi
I have a couple pieces that might help.
1. Check the top and bottom constraints of the items. Sometimes these constraints are set to weird levels automatically. I've had times when I place a column on a level and it makes the top constraint the level I'm on. So the column is visible, but only the top of it.
2. Try creating a new 3D view using a camera. I always us cameras for 3D views as they are much more flexible than the standard 3D view.
Hope this helps
KotairaKeila
If you are in the {3D} view, not in the analytical one, maybe you should check the Discipline in Properties. Try change it to Coordination or Architectural.
