Strategy to model existing metal building
We have a large metal building and I design lighting and HVAC upgrade. I don't do any structural work, but still want to represent the building relatively accurately. That way I and contractor know where the structural elements are to avoid. Below is a typical section showing girts and purlins. I think I'm fine modeling the main frames with oob families. But the girts and purlins may be time-consuming, so I look for an efficient way.
My initial idea for the wall is to use a stacked wall and only model the metal cladding to leave space for the girts. For the girts I was wondering if some beam system or other automatics way is better, or if I just place them manually. There are many bays, but I can just pretend to use a very long girt. I'm not quite sure how to handle the batten insulation. It kind of will be in the way of things, bit isn't an obstacle like structural elements. Below the stacked wall i created:
for the roof I could leave the roof as tick as it is since the purlins sit under the roof. I don't know if beam systems, or using structural floors or something would work better.
I'll try some things. but if someone has done that before and can give some hints on what would be efficient to do, that would be great.
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
