Strange behavior of a revit file
raresh1905
Message 1 of 11
raresh1905
I work in this model for the past 4 month and i got a really strange problem. The mullion are no more aligned to the lines (they are dancing on the curtain wall lines, the floors and stairs aren't aligning in 3d view or in section.
if a chose any of the object from that project and paste in a new one, everything looks good, if i put a dimension they are good but they are not showing right even when i plot them.
In the picture i attach you can see how mullions are dancing and how the curtain wall line looks like...
even a normal wall isn't filled correctly and its just a normal fill.
if i copy every element from this file to a new file everything looks right.
i tried open the file with audit, making a new copy, nothing works.
The procesor its around 5-30% and the memory 61% and the video card never passed 45% on loading.
i tried activated smooth lines with anti-aliasing but there was no difference.
can someone point me in a direction what can i do, or how can i transfer everything in a new file in a easy way? linking the document to a new file isnt working is showing the same result
I tried copying every level individually to a new file, same think happened. if i copy just a element its ok, if i copy the whole file its the same thing, even if i isolate a wall still dancing...
Thank you!
Replies (10)
Message 2 of 11
raresh1905
when i edit the sketch of a stair the sketch looks good after clicking ok goes wrong, i upload a before and after... any idea?
Message 3 of 11
Post a screenshot of all your warnings (expanded) in the project.
Message 4 of 11
Do you have any elements such as CAD import/link too far away from the Origin? Create a new uncropped floor plan (do not duplicate from an old one), zoom extent and see.
Message 5 of 11
raresh1905
Here it is a screenshot and i also export them as html
. ProiectAdunat Error Report (09-Jun-19 11:18:04 PM)
Error messageElements
There are identical instances in the same place. This will result in double counting in schedules.Structural Framing : UBP-Universal Bearing Pile : IPE 400 : id 539543
Structural Framing : UBP-Universal Bearing Pile : IPE 400 : id 547994
Highlighted floors overlap.Floors : Floor : Generic 300mm : id 393360
Floors : Floor : Generic 300mm : id 477839
Highlighted floors overlap.Floors : Floor : Generic 300mm : id 397000
Floors : Floor : Generic 300mm : id 445300
Floors : Floor : Generic 300mm : id 446405
Floors : Floor : Generic 500 : id 498492
Floors : Floor : pamant : id 574873
Floors : Floor : pamant : id 575003
Highlighted floors overlap.Floors : Floor : Generic 500 : id 498492
Floors : Floor : Generic 500 : id 511940
Highlighted floors overlap.Floors : Floor : Generic 150mm : id 609870
Floors : Floor : Generic 300mm : id 609969
Floors : Floor : Generic 400 - scari : id 590679
Floors : Floor : Generic 400 - scari : id 590728
Floors : Floor : Generic 400 - scari : id 591846
Floors : Floor : Generic 400 - scari : id 591895
Highlighted floors overlap.Floors : Floor : Generic 400 - scari : id 590672
Highlighted walls overlap. One of them may be ignored when Revit finds room boundaries. Use Cut Geometry to embed one wall within the other.Walls : Basic Wall : Generic - 500 : id 506612
Walls : Basic Wall : Generic - 500 : id 512030
Highlighted walls overlap. One of them may be ignored when Revit finds room boundaries. Use Cut Geometry to embed one wall within the other.Walls : Basic Wall : 40 - 30+10 : id 520298
Walls : Basic Wall : Generic - 150 : id 558666
Stair components are not continuously connected. This may cause incorrect representation and annotation.Stairs : Precast Stair : Stair : id 590300
Stair components are not continuously connected. This may cause incorrect representation and annotation.Stairs : Precast Stair : Stair : id 591467
Stair components are not continuously connected. This may cause incorrect representation and annotation.Stairs : Precast Stair : Stair : id 603322
Type : Model Groups : Model Group : Scari Promenada 400 ingust : id 603319
Stair components are not continuously connected. This may cause incorrect representation and annotation.Stairs : Precast Stair : Stair : id 605760
Type : Model Groups : Model Group : Scari Promenada 400 latita : id 605757
Message 6 of 11
Bingo, @ToanDN!  Betcha that's it.  Not just CAD -- any element more that 10 miles out.
@raresh1905:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/CloudHelp/cloudhelp/2019/...
Message 7 of 11
That's all the Warnings you have???  Good job, my man!
Message 8 of 11
raresh1905
Ok, my survey point and project points are 320km away from the project i dont know how i did this, but i manage to move the survey point to the middle of the project, but the project point it cannot be moved more then  16km, so what can i do?
Message 9 of 11
The 10 mile radius limit rule applies to geometry, and is measured from the Internal Origin of the Project. To find the Internal Origin of the Project, select the Project Base Point, unclip it and click on "Move to Startup Location".  The location the PBP lands at is the center of the 10 mile radius.
The only way to correct for elements that lay outside this radius, is to physically move them closer to the Internal Origin -- because the IO Location is fixed and cannot move.
Message 10 of 11
raresh1905
ok... i was scared about this as the only solution... thanks for the help !!
Message 11 of 11
raresh1905
@barthbradley  @ToanDN  Work like a charm everything look perfect now thanks for all the help!!!
