STL Exporter Revit 2020
Message 1 of 28
Where's the STL Exporter for Revit 2020?
Replies (27)
Message 2 of 28
Still waiting....it can take time.  Only a couple of extensions have been released so far...
Message 3 of 28
David_W_Koch
You have probably already found it, but for anyone else looking for the Revit 2020 STL Exporter, the add-in was released on May 29, 2019.  It should be in your Autodesk Account, or in the Autodesk Desktop App.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Message 4 of 28
joe
Can someone send a link to this. It is not showing up on my account
Message 5 of 28
If required, you can export to DWG and from AutoCAD export as an STL file.
Message 6 of 28
joe
Does that mean an add-on STL exporter does not exist for Revit 2020?
Message 7 of 28
The stl exporter for Revit 2020 does exist.
Go to https://manage.autodesk.com/home/ and look up to
"all products & services" --> Revit --> Revit 2020 --> show all downloads --> updates & add-ons ...
there you schoud find it.
I hope my guide to the download helps a little bit, sorry but i don't know any direct link.
Message 8 of 28
THANK YOU !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Message 9 of 28
jsam
This is not working out for me. Has there been an update to how to get the STL exporter add on since this discussion?
Message 10 of 28
jsam
Never mind, I found it.
Message 11 of 28
I still can't find it.  It doesn't appear under my Autodesk account.  Could it be because we are educational?
Message 12 of 28
Nevermind.  Someone from Autodesk Support finally provided me with a link to download it from OneDrive because it does not appear in my download portal.  Probably because we are educational?
Message 13 of 28
AndycMacp
Hi, can someone please point me towards the 2020 download? I can only see the 2018 version in my available add-ins.
Many thanks
Andrew
Message 14 of 28
ropopoin
Observer
Observer
were?
Message 15 of 28
Message 16 of 28
I can´t find the add-in in my autodesk account manage page. I only have the 2018 version but not the 2020. How can I fix it?
Thank you!
Message 17 of 28
Can anyone point me in the right direction?
I've downloaded and installed all updates from Autodesk but still no STL Exporter.
Or can someone send me file for the add-on to install.
Much appreciated,
Cheers
Message 18 of 28
I am having the same problem, did you find the download file?
Message 19 of 28
Alguien pudo ubicar la aplicación Stl Exporter??
Message 20 of 28
gustavoEXPBR
Também estou com o mesmo problema.
Não aparece no add-in
