Steel frame flooring
jinergoh721
jinergoh721
Good day.
do anyone knows how to model the steel framing floor( the girder)  below  as shown in photo? In a quick & slick way.
rxi.gg
You can create a structural family with an extruded profile parameterized in length.
Otherwise, in a simpler way you can do it like this video
https://www.youtube.com/watch?v=hV8f2EhTRpQ
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
For the girders, use Beam Systems. It's "quick & slick".  Promise.
How to Make a Beam System in Revit - Bing video
jinergoh721
GODDAM its so much quicker than Model in place, lol.
jinergoh721
Hi @barthbradley ,
I tried that vid approach. First is that horizontal element does not appears in photo 1,
Then it is place on Ground level, I want to move it down a bit by trying on ELEVATION, but cannot works.
I do exact instruction in the given videos.
THX,
Jiner.
