It depends on how you create the stairs. If you create them using the standard Run and Landing tools, then landings are created at breaks in the stairs (such as in L-shaped or U-shaped stairs) after you create the second run of stairs.
If you create stairs by sketch, then no, you must draw the landings yourself.
Yes,
Howard Munsell
there's a learning curve on stairs...even straight ones.
