Stairs that can be accessed from 3 sides
5 REPLIES 5
oda.3
421 Views, 5 Replies
oda.3
Observer
Observer
Im trying to create stairs that can be climbed from 3 sides of the stairs, I'm having issues trying to make it work, I've attached an image of what I'm trying to go for, has anyone got an idea of how i can go about creating this kind of stairs in revit?
5 REPLIES 5
in reply to: oda.3
You can get there with Stair by Sketch.
..you can also use Floors.
norbert_szlezak
in reply to: oda.3
norbert_szlezak
@oda.3 in case one sketch doesn't work fine try to insert 3 runs in one stairs family. You can modify a run by Convert and then Edit Sketch
oda.3
in reply to: barthbradley
oda.3
Observer
Observer
not sure how yours is showing in 3d, i did mine and it seems to show in plan view but for some reason it doesn't show in 3D view or elevation, I have stairs turned on in visibilty graphics but its still not showing in 3D
RDAOU
in reply to: oda.3
RDAOU
@oda.3
I would start a stair and use 3 Sketches, one for each side...I like the diagonal cut at the corners better than 1 continuous tread
2022 file attached
@oda.3
2022 file attached
in reply to: oda.3
Play with these settings or just break into separate stairs abutting each other. Or, even easier: use floors atop one another.  Floor Type Thickness = Riser Height.
