Stairs Riser not lining up with Stinger
Message 1 of 12
My riser and stingers are not lining up and it's driving me slightly mad.
I'm hoping someone can help me elucidate this. I've attached the file with the single stair.
Replies (11)
Message 2 of 12
deselect end with riser.
Message 3 of 12
Thanks @barthbradley, it seems to work for new stairs runs.
Do you know if it is possible to deslect it for existing stairs? I can't seem to find the option and the documentation not helpful on this topic.
Message 4 of 12
Nevermind, I got it. I had to TAB select the stair part of the stair instead of the assembly.
Thanks! Smiley Happy
Message 5 of 12
Yes you can set it as default. When you start a new stair, open the drop-down box under "Stairs" in Properties and select "New Stairs: Run" and then deselect "End with Riser." That will remain the default until you redefine "New Stairs:Run".
Message 6 of 12
Solving problem 1 created another problem...
Without the final riser, all the stairs say they are mising a riser.
I've also noticed that adding the riser, extends the thread by 1-1/4" for some reason.
Do you know if there is a way to get the final riser without the weird 1-1/4" extension?
Thanks!
Message 7 of 12
That is the Nosing distance.
Message 8 of 12
I was able to remove the nosing distance and the end of the stair looks great, but now the noses are all screwed up.
Is there a way to get a good stairs for both nosing and end riser?
Message 9 of 12
Don't you stairs have a top landing?
Message 10 of 12
Yes
Message 11 of 12
Add the top landing see if it helps.
Message 12 of 12
Highlight the Carriages and select a different Upper End Cut
