Stairs Railing
d.ola
Stairs Railing
d.ola
Does anyone know how i could create the balusters such that they adjust to the Top Banister. Thanks in advance
See Picture Attached
Replies (13)
Are you talking about this?
Landing Height Adjustment:
oladamilola
No. I meant this
I'm not clear on what I'm looking at. It does look screwy though.
Post the File.
oladamilola
Hi @barthbradley Here's the file. Thanks
This?
oladamilola
Yess. The only issue I have is the baluster extends beyond the boundaries I drew at the beginning and again at the end of the railing. Do you know of a workaround to trim the overshoot?
Change the offset from Host. No?
Currently, the Base Offset is -5m.
So your upper run railing and lower run railing are on the same plane is the intent?  A workaround is using a curtain wall and edit profile for that railing.
oladamilola
This doesn't work. i get the highest chance with all balusters extending to the lower Railboundary (and beyond) with values starting from -0.5m.
oladamilola
Yes. That's the intent due to space constraints.
Phew. I've been trying to avoid the curtain wall workaround. But just might have to resort to it
What do you mean "it doesn't work"?  Maybe I'm not understanding what the aim is here.
oladamilola
It doesn't work was in reference to changing the Base Offset like you suggested.
And the overshoot i mentioned is marked Red with the attached image. The aim is to do away with the overshoot
