Stairs nosing length "Shifts" the stair?
saf-a
saf-a
Hello
when adding a length to the nosing in the run it affects the stairs position
Is there a way to make it just extend the nosing while keeping the stair in place?
I don't want thisI don't want this
mauricio_mssf
Hi @saf-a
Go inside you stair and just mark "Begin with Riser" on properties.
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
If your steps have a Pinocchio nose like that then you may need to edit the riser profile and push it back from the origin vertical ref plane.
