Stairs and railings
Stairs and railings
btobias
Message 1 of 8
Stairs and railings
btobias
I downloaded the stair and railing sample files from this website for use in my project.  I'm using Revit 2016.  When I try to open the files, it says they were saved in a later version and cannot be opened.  Any idea where or how I can get the 2016 version of these files to download?
Thanks.
Replies (7)
Message 2 of 8
Thanks.
Where did you download them from?
Message 3 of 8
btobias
I downloaded them from this website.  I googled "handrails for Revit 2016", and it brought me here showing me the sample files for stairs and handrails.
Message 4 of 8
Can you provide a link?  "This website" is pretty nebulous...
Message 5 of 8
btobias
The link is below.  Sorry, for whatever reason, it won't allow me to copy it as a hyperlink.
https://knowledge.autodesk.com/support/revit-products/getting-started/caas/CloudHelp/cloudhelp/2016/...
Message 6 of 8
Try this: https://knowledge.autodesk.com/search-result/caas/vhelp/help-dev-autodesk-com/v/Revit/enu/2013/Help/...
ADSK rarely changes their sample files; probably the same as the newer version you grabbed earlier.  Upon opening, they'll update to your version.
Message 7 of 8
btobias
Excellent, thank you so much!  That worked perfectly.
Message 8 of 8
loboarch
Actually the older one "looks" the same, but there are a few subtle differences in the files.  The 2016 page somehow got updated with a link to the 2017 downloads when it should not have. The 2016 version of the stairs can be found here.
http://www.autodesk.com/revit-stair-samples-2016-enu
Jeff Hanson
Principal Content Experience Designer
Revit Help |
