Stair support
Stair support
shahin_kiyomarsi
Stair support
shahin_kiyomarsi
Can someone explain why my supports are not attaching to each other?
When I try to further extend out, this happens
How are they supposed to connect at that tight switchback?  If you want a clean connection then extending the landing is the right approach.
shahin_kiyomarsi
I did it, its still not attaching properly.
Share your stair model here.
anze.kumar
I think the issue might be:
1. revit generates "small" part of supports because the stair path does not start at the same line
2. width between Stair shoulders is not wide enough.
