Stair Sketch Mode
Stair Sketch Mode
PhilvK
Advisor Advisor
Message 1 of 8
Stair Sketch Mode
PhilvK
Is it no longer possible to convert an assembled stair to sketch mode so that you can lengthen the stringers?
Replies (7)
Message 2 of 8
hmunsell
What version of Revit are you using?
Howard Munsell
Message 3 of 8
RDAOU
@PhilvK
I just check in 2019, 2020, 2022 ...the option to Convert assembled stairs to sketch is still there!
Edit stair >>> Select Either the run OR landing and convert to sketch (selecting both will not show the convert button) ... or is it something else you meant?
Message 4 of 8
It is possible? Edit the assembled stair, select a run or a landing, convert to sketch.
Message 5 of 8
PhilvK
Yes, I've gotten that far, but cannot select the stringers to be able to extend them past the last treads.
Message 6 of 8
RDAOU
@PhilvK
Stringers follow run or landing...I don't think they ever had grips allows them to be extended past the stairs (sketch or no sketch...they have only the extensions available in the properties palette.
Model the stairs without them and do the stringers as extrusions maybe
Message 7 of 8
PhilvK
Version 2017 had grips that would let you drag the stringers so that they extended as shown in the jpgs below. Why not 2021?
Message 8 of 8
RDAOU
@PhilvK
Interesting to see that! 2015 and 2017 are the only 2 versions of Revit which I have never used...I did check this morning in 2014/16/18/19/20/22 ....Stringers are bound to the Tread/Nose...not the stair boundary line of the Assembled Stair shown in your image
To achieve that 2" extension we have always done it using one of the following methods:
Option A: Model the stairs without the stringers and use the following to substitute the latter (I think this is pretty much easy no images are required):
  1. Beams
  2. Walls with edited profiles
  3. In-Place Extrusions or sweeps
  4. A swept profile in Line Based Family which has an angle cut at start/End
Option 2: Sketched Stair + uncheck Begin with Riser  (See image 1 Below)
  1. Convert the run to sketch
  2. reduce the depth of the first Tread to the desired offset of the stringers
  3. Uncheck begin with riser (which basically embeds the first step in the floor slab)
  4. finish sketch
Option 3: Use custom Treads and Risers  (See image 2 Below)
  1. Model a custom profile for the Treads and the risers
  2. make sure to set the proper function of the profile to Tread Or Riser
  3. In the family - Give the Profile a 2" offset from the Left/Right Ref Plane (this is where the stringer stops)
  4. In some cases you might want to consider modeling the Tread profile to include the Riser (See image 3)
    • NOTE: You will need to uncheck the Riser in the Run's properties
    • NOTE: you can add Detail components if required
IMAGE 1 - Embedded first stepIMAGE 1 - Embedded first step
IMAGE 2: Run type with Custom Tread profile + Custom Riser profileIMAGE 2: Run type with Custom Tread profile + Custom Riser profile
IMAGE 3 - Tread + Riser in 1 Profile FamilyIMAGE 3 - Tread + Riser in 1 Profile Family
