Stair Risers are missing
TasnimTarannum
TasnimTarannum
I am designing a multistory building to minimize file size. I used the PURGE UNUSED command, but then encountered an issue where the riser of the monolithic stair is not visible on some floors, while it appears correctly on others. 1.jpg
Are you saying they appeared correctly BEFORE using purge all tool?
TasnimTarannum
Yes, and they appeared correctly up to 3rd floor. Then I re drew but no changes.
<Above> subcats turned on?
TasnimTarannum
TasnimTarannum
My bad, found the mistake the shaft opening wasn't properly placed.
