Stair Railing Issues
jordan-stewart24
Observer Observer
jordan-stewart24
Observer
Observer
To those who are more  experienced to this than I am I thought I would put the question out there as I have no idea what the fix to this problem is.
any time i am going to create this handrail on a curve I cannot for the life of me get it to work whether I'm doing it as a sweep, handrail, you name it and I've tried with the experience I have so just wanted to put out there if anyone knows the solution to this I would be extremely grateful.
Mike.FORM
This issue you are having is that you are changing 2 orientations at 1 location (turning left and angling up) which is not possible with that shape as it has only 1 axis of symmetry.
In this situation you need to start at the flat portion make a left turn that extends flat a minimum of the width of the handrail (may be able to be less) and then angle up to meet with the sloped portion.
jordan-stewart24
Observer
Observer
Thanks for the prompt reply Mike, I'm still not 100% how I would go about doing this..is there a way of you showing?
Mike.FORM
Whoops, wrong post.
Edited: You just need to adjust the path of your railing so that you have a flat segment to between the angled portion and the turn.
RDAOU
Hi @jordan-stewart24 It would make the attempts of other to help you much easier if you post the stair & rail rather than forum visitors trying to recreate the issue then providing a solution
Regards
