Stair railing half mounted half floor support?
Good afternoon,
I've been working on a set of stairs with a railing on the left which I would like half to be wall mount supported and the other half to be floor supported? I'm new to Revit and I'm getting on ok but this has been mind boggling me for days now! Please see attached screenshot. (Excuse the wall from ground floor, I haven't quite managed to figure that one out yet!)
Those supports can be moved.  Do you know that? Select one, unpin it and then nudge it.   Is that what you are after?
Hi barthbradley,
Thanks for your response.
Partly. I shall remove the top 3 wall mounts via your solution as they are not needed. But I also need to work out how to support the handrail from the first floor via balusters? Any ideas?
NW
Railing. Balusters and/or End Posts. Check out the OOTB  Newel Post and see if that works for you.
