My Revit 2021 project hangs every time I try edit / move / delete basic wall types.
try to tick audit before opening the file and see if helps. thanks
Thanks Ennu,
I have tried auditing the file. I have also performed numerous other health checks as well.
Unfortunately, none of the above seemed to make any difference.
okay, have you try to install latest updates from autodesk and see if helps. thanks
Can you upload the file sample so we can see if we run into the same issue?
Hello we have also started to encounter this very issue using Revit 2021. We are unsure what the route cause is.
We have cleared the BIM360 cache, audited the model, removed redundant rooms and still this issue keeps occuring.
Regards
Ricky
Hi Ricky,
This issue was a very frustrating one to troubleshoot because in order to test the model after changing something, the model would hang/freeze when I tried editing or deleting a wall. I used this wall as a testing point, and so I had to force close my Revit countless times to find the route cause of the fault.
In this case, I narrowed it down to a single corrupt plan view. Once this view was removed the problem was solved.
So I'd suggest that you try removing all the views in the project, and test to see if it helps. If it helps then you can start removing sets of views until you narrow it down to the culprit.
Hope this helps.
Thanks for the reply I will have look and see if that helps isolate the problem.
Regards
Ricky
