Stair Problem: Landing is not perfect rectangle.
jaza008
jaza008
Not really a problem since Revit is working as it should be but I really want a way around this.
the image should be clear of what I encountered.
to summarised
I created the stair with nosing.
I close the distance between stair's run [last image]
The Revit still creates little separation line on landing.[2nd image]
landing model sketch boundarylanding model sketch boundaryScreenshot 2021-01-06 090000.png
It's pretty. Can you post the file?
jaza008
Here here, sorry for a long time. completely forgot about this.
This is all I got for you...
Here goes.
jaza008
Wait how???
The revit file was attached in the previous reply. Edit the run type you shall see. Then the landing sketch boundary is a simple rectangle.
