Stair Path on stair in linked model showing different line weight and up direction
- Mute
- Permalink
- Report
I am working in Revit 2022 with a linked model coming from another firm, live linked to ours through BIM 360. When I go to add the stair path annotation to any of the stairs in the linked model it gives it a heavy line weight. Object styles are set to 1 for stair path, and look correct on stairs within our model. I've checked all VG overrides and tested in a few different views with the same result. If I copy their stair into our model, it also shows the correct line weight.
The other odd thing is that the UP annotation also does not show up. When I drag it I can see it, but the second I drop it disappears again. Screenshots below of each.
There are some errors with their stairs, but I can't see why this would affect the stair path annotation in any way. Is this just a 2022 bug? Hoping someone else has run across a solution to this! in model stair
linked stair
