Stair number doesn't show up
Message 1 of 9
Hi Friends. I can't change the step numbers. I have attached the file for your review. Thank you for help.
Replies (8)
Message 2 of 9
MostafaElashmawy
after modelling a stair, the steps number will work only as a way to control the the height of the riser.
to change the actual steps number, after editing the step number, click on edit stair and drag the end of the stair to add more steps.
Mostafa Elashmawy
Message 3 of 9
No, I just need to change the annotation of UP to 6 UP.
Message 4 of 9
RDAOU
BUMP
...it does change if you hit Enter instead of Apply!
Message 5 of 9
Message 6 of 9
RDAOU
why does it work on yours and not mine!!
Works when I hit Enter instead of apply
Message 7 of 9
It should. Just type in the text box next to Up text.
Message 8 of 9
Toan, It doesn't work for me.
Message 9 of 9
Here's your file.  Use Enter, not Apply button after typing in 6 Up.  See @RDAOU post above.
