Stair is appearing over a Room fill
roedigerF6NSW
Message 1 of 8
roedigerF6NSW
My floor plans have a color fill scheme associated with rooms- as you can see in the attached image, the stair below the primary bath is showing up over top of the color fill. Can anyone troubleshoot this? Thanks
Replies (7)
Message 2 of 8
is color scheme in background or foreground?
Actually, the linework you see for stairs in plan view is symbolic linework - not model linework.  Hide in View by Element, Category or Filter.
Message 3 of 8
ralphdenhaan
Have you checked the Color Scheme Location? Can you set it to Foreground?
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Message 4 of 8
roedigerF6NSW
It was set to background, thanks
Message 5 of 8
I thought you wanted to hide the stairs completely.  That's why I edited and added the remarks under my question "is color scheme in background or foreground?"
Message 6 of 8
roedigerF6NSW
No, I just wanted to prevent those bottom treads from showing thru the color fill- honestly changing from background to foreground isn't even an optimal solution because then I have to use room separation lines everywhere to clean up the color fills. If there's another solution that would be helpful, otherwise the foreground is the best I can do
Message 7 of 8
Set Stairs category to 100% transparent.
Message 8 of 8
boyd_johnson
I'd say @ToanDN is correct.  Although the issue is resolved for the stair if you change the Color Scheme Location to Foreground - this causes undesireable behavior of the room colors at doorways.
