hi
i want to show riser & structural lines in plan view . it is highlighted with blue when chose the stair, but it doesn't show normally. Please see atachements.
Solved by ToanDN. Go to Solution.
ccomponent
it is normal plan view
it is forbidden to share file with 3rd person 😕
Can you show your stair run settings? I bet your nosing length is 0. Change it to something else.
What are your Object Style Settings for Nosing Lines and Riser Lines?
...actually, just Riser Lines. That's what is missing.
You may be setting VGOs under the wrong tab. Are the stairs resident in the Project, or are they in a Link? Perhaps using By Link View or Custom settings?
