Stair Double Cut Line Graphics
serenalZ37LQ
serenalZ37LQ
Hi all. I am in Revit 2021 but I've seen this issue in all versions. I have a stair and want to show a double zigzag cut line. The stair is on Level 8 and there is a stair above and below. When I apply the double zigzag cut line I can see the stair below in between the two cut lines. This area should be blank. See image for further clarification. How can I have this be blank without hiding the stair below or adding a masking region?
Replies (22)
Is this what you did?
Like this?
serenalZ37LQ
Yes graphically that is what I am trying to accomplish. Do you have a stair below in that image? If so, can you share how you removed the bottom stair from in-between the cut lines?
serenalZ37LQ
Yes I did adjust the distance between the cut lines but regardless of the spacing the stair below still shows.
So you have stairs underneath?  Hide then in the view then.
...you could use a Plan Region as well.
https://help.autodesk.com/view/RVT/2019/ENU/?guid=GUID-7CA9496D-205E-4838-A669-37C1DA7DEB67
NOTE: Floors, structural floors, stairs, and ramps located outside the view range use an adjusted range that is 4 feet (about 1.22 meters) below the bottom of the primary range. Within this adjusted range, the elements are drawn using the projection line weight for the category. If they exist outside this adjusted range but within the view depth, these elements are drawn using the <Beyond> line style.
https://help.autodesk.com/view/RVT/2019/ENU/?guid=GUID-58711292-AB78-4C8F-BAA1-0855DDB518BF
serenalZ37LQ
Trying to avoid masking regions since they are view specific and can get messy if the stair moves or cut line moves. Hiding the stair is also view specific and hides the entire stair below which is not graphically correct.
Can you describe how a plan region would solve this? I've used them to adjust the location of the cut lines, I don't see how it would remove that portion of the bottom stair. I should also add that adjusting the view range does not solve the issue.
I never said anything about Masking Region. I said hide the below Stairs.  And as for Plan Regions, I posted a couple of links for you.  Is that not satisfactory?
...by "hide" I simply meant exclude them from the View.  Either by selecting and hiding them via Hide Element in View - or via a Plan Region.
serenalZ37LQ
Your first link led me to room calcs - I'm not sure how that is relevant? Let me know if I am missing something there...
A plan region is not a good fix because it does not remove that portion of the stair only. Also, if I have 100+ stairs that have this issue it would be very inefficient to create a plan region for each one. I appreciate the effort but I don't see either of those solving my issue.
See attached.
Can you share your file?
serenalZ37LQ
yes - exactly...is there a particular setting you used? please share.
Already did.  Open the Revit file.
serenalZ37LQ
Not sure I understand what you did. See file attached in next message.
serenalZ37LQ
Not sure I understand what you did. Attached is a file including my original stair, a new stair I created and converted to multi-story stair, and a copy of the original converted to multi-story stair. None of them are displaying correctly. Can you explain what you did to achieve the solution?
**edited to add an updated .rvt
serenalZ37LQ
Also - when i take your file and stretch the level elevations to 15' (closer to what my building shows) the issue re-appears.
If I recreate the stair and make it a multistory stairs then the mask still works.
serenalZ37LQ
I see. Is there any way to achieve this goal without having to recreate the stair? That wouldn’t be a practical solution for most of our projects since we work with high rises and have multiple stairs throughout the buildings.
Hiding that stair linework is not an option for you?
...oh, I hadn't noticed that you posted an example file.  How about the Linework Tool?  Probably impractical as well.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
