If you mean an L shaped stair with a landing, you would just use 2 runs within the stair editor. If you need something more complex, just draw it out using the riser command, place all your risers where you want them, then draw the boundary lines. Note you want to start at the bot or the top as you draw them. If you post a sketch of the stair I maybe able to help better.
