Stacked Walls
Stacked Walls
gkwas
Stacked Walls
gkwas
I created a stacked wall, 2x8 wd stud with 4" cmu veneer and 4" SF CMU veneer.  Individually, the walls show all detail in plan, as a stacked wall they show no detail.  Can anyone tell me why this might be happening?  Thanks
Alfredo_Medina
It's not clear what the issue is. If I create a stacked wall, and set the detail level to fine, it displays properly as per the detail level, both in plan and section views. More information on the issue would be helpful.
Giosue.Garita
Hello Greg,
My name is Giosuè. I am a Revit specialist.
Please click HERE and review carefully this article which contains a workaround that may help us in resolving this issue.
In case this information does not allow to resolve this, please let me know so we can further research on this matter.
If I don't hear from you within 2 business days, I will archive the case (despite of it, you can still post your thoughts here).
Cordiali saluti / Kind regards
Giosuè Garita
Autodesk, Inc.
