I'm modeling my apartment building. It is basically an H-shaped building, but there are a couple of exterior passageways under the building from the side to the rear courtyard (images attached). So I can't just use a series of stacked walls around the perimeter. The brick should be continuous but it is not wrapping properly. Looking forward to solving it!
Well you have several situations all wrapped under 1 post...it would have been easier to address if you would have highlighted them to be more specific
First image: The gap. This can be due to the wall's upper constraint and/or the type of join with the slab
Second Image: the Jambs. If you have used an Opening, the wrapping applied in plan view will not be applied neither in Elevations/Sections nor in 3D.
Third Image: Walls not joining properly - happens when you have lots of things going on at one corner or when the location line of one wall is Center while the other is Face... Try any of the following
If you find the above too complicated, upload the rvt file and can explain it in a screencast
Thanks for your quick and detailed reply, DR.RD! I had a hard time understanding the 1st two (lots going on in my life right now) but tried join geometry with plan and the options are greyed out so I can't edit. Don't know if it's relevant but I have Revit LT.
I'll try and address the rest of it later.
