Message 1 of 15
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've been noticing the strangest thing on my projects and if you reference the attached pictures then you'll see what I'm talking about. Everything looks normal in Revit and even when I print out the floorplan, however exporting my views to PDF changes the format of the text and adds a square next to the text? I'm lost on what part of the PDF process is causing this to happen?
Just a side note, this only affects dimensions that I've overrode the text value on. Again it is literally only when I export my plans to PDF that this problem arises? Any ideas?
