spot level related to 0 level
GA-LT
GA-LT
why there is no option to add spot level realtive to 0 level and we need install for example SOFiSTiK BiMTOOLS
michael.coviello
Autodesk Support
Autodesk Support
Would you be able to explain further or post a small model?  You can use a spot elevation that uses a relative elevation based on a level which is at 0' elevation.
If this is not the issue, could you please explain by adding a screenshot or a small model.  Thank you.
Michael C
Technical Support Specialist
What's New in Revit 2023 | Autodesk University | Revit Blog
