revit rever configuration
Buen Dia
Estamos intentando vincular un Revit Server con el archivo RSN.ini, donde tenemos implementado un servidor físico activados el Host,  Accelerator y administrator, y podemos  acceder al Revit Server Administrator sin problemas.
Se crea el archivo RSN.ini en la ruta C:\ProgramData\Autodesk\Revit Server 2016\Config
Tanto en el servidor como en los equipos cliente.
Pero cuando se intenta guardar el archivo presenta el mensaje <<Esta operación no se ha podido completar. Inténtelo de nuevo.
Nos gustaría saber qué tipo de permisos se deben dar al servidor para que no haya problemas al momento de guardar, o si estamos omitiendo algún procedimiento
BIMologist_
Had to run translate
Check this LINK
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-11C78619-DFAF-4496-8AC8-008B7D218164
This is IMPORTANT
 Note also that the model (and all of its subfolders and their contents) must have full access to CREATOR OWNER and NETWORK SERVICE in order to function correctly in the new location.
 C:\MyRevitServerData\
Make sure that the Parent Folder to Projects/Cache/TempRepository
has the following permissions
We are trying to link a Revit Server with the file RSN.ini, where we have implemented a physical server activated the Host, Accelerator and administrator, and can access the Revit Server Administrator without problems.
The RSN.ini file is created in the path C:\ProgramData\Autodesk\Revit Server 2016\Config
Both the server and client computers.
But when you try to save the file presents the message &lt; could not complete this operation. Try again.
We'd like to know what kind of permissions must be given to the server so that there are no problems at the time
BIMologist
- Nauman Mysorewala
Did you find this post
helpful? Feel free to like this post.
Did your question get successfully answered? Then click
on the ACCEPT SOLUTION button.
jonathan_moreno
Hola Ediel:
Gracias por participar y colaborar en Autodesk Revit Answer Day!
Hay recursos disponibles en los siguientes enlaces:
Instalación y configuración de Revit Server
Configurar permisos de administración
Espero que esto ayude, gracias!
Si mi respuesta a su pregunta le ayudo a encontrar la solucion, haga click en “Aceptar como solución”. Esto ayuda a todo el mundo a encontrar solución más rápidamente!
Jonathan M.
Technical Support Specialist
