Spot Elevations: Gap From Host?
se.JPGHi,
I am wondering if there is a way to allow a slight, CONSISTENT gap to the spot elevation families. I've attached an image of the issue. As you can see, the line goes through the wall, to the soffit I have. I need to have no annotation lines intersecting the actual building. I already have an independent symbol to use, but I'm trying to save a little time by trying to find a solution to this issue. Is it as simple as a parameter? Even if the gap isn't consistent, as long as I can modify the end point of the SE without making it a symbol, it would make life easier.
Thanks!
Isn't that a Level (not Spot). Levels can break in the middle (click on break line icon).
Corsten.Au
This is just a workaround if you are looking for.
You can put a " Filled Region " in " Spot Elevation Target fill
to get the gap between elements and spot elevation..
I have shown two fill region for example..
PS.. you may need to keep a duplicate and use it for your specific Spot Elevation.
Else this target fill will affect many places.
1. Spot elevation final look.
2. Spot Elevation Target fill -
Corsten
Building Designer
Viveka_CD
Hi @Anonymous
I'm just checking back to see if the resolution by the experts helped with your issue.
If so, please click on 'accept the solution' button to benefit others seeking similar solutions.
