Createan HVAC Plan
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
PhilvK
717 Aufrufe, 11 Antworten
Createan HVAC Plan
If I want to create a Mechanical plan for my eyes only for coordination, and one that will not have all the HVAC ducts that are on the ‘real’ MEP plans, is the process to start a new project with the Mechanical template, and insert the Architectural model? The Autocad procedure equivalent would be to xref the Architectural plan into a new drawing.
11 ANTWORTEN 11
Nachricht 2 von 12
Sahay_R
als Antwort auf: PhilvK
One word answer for you - yes.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 12
PhilvK
als Antwort auf: Sahay_R
Thank you ! That works rather nicely, although it looks like you can’t have both the Architectural and MEP models open at the same time, correct?
Nachricht 4 von 12
Sahay_R
Right again!
Rina Sahay
Nachricht 5 von 12
PhilvK
What would be the best way to bring that ductwork only into my architectural model?
Nachricht 6 von 12
Sahay_R
1 - To create the ductwork - you would need to link the architectural model into the mechanical model.
2 - To bring the ductwork into the architectural model once it is created - link the mechanical model into the architectural model.
Rina Sahay
Nachricht 7 von 12
PhilvK
I did do that but was having problems with the Level labels, since they are
different. I will try again. Thank you!
Nachricht 8 von 12
Sahay_R
You can hide items from the Arch model in the Mech model, and vice versa. Go into VG and look for RVT Links. Select the linked file and you will be able to control the visibility of Model / Annotation elements and Worksets.
Rina Sahay
Nachricht 9 von 12
PhilvK
When I go into VG > Revit Links, the model is listed but there are no categories to turn off. I am trying to turn off the Mech reference's Levels..
Nachricht 10 von 12
PhilvK
Found it!
Nachricht 11 von 12
PhilvK
Found how to do it:
Went to VG > Revit Links > Selected the referenced file title > Selected Custom under the Basics tab on the RVT Link Display Window ? Go to Annotation Categories > Select Custom in the drop down > and turn off the category. Whew!!
Nachricht 12 von 12
Sahay_R
When you come to the part of VG that lists the links, click on Host View under Display Settings - that will take you to where you need to be to c ontrol visibility of the link
Rina Sahay
