Spot Elevations: Gap From Host?
09:06 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am wondering if there is a way to allow a slight, CONSISTENT gap to the spot elevation families. I've attached an image of the issue. As you can see, the line goes through the wall, to the soffit I have. I need to have no annotation lines intersecting the actual building. I already have an independent symbol to use, but I'm trying to save a little time by trying to find a solution to this issue. Is it as simple as a parameter? Even if the gap isn't consistent, as long as I can modify the end point of the SE without making it a symbol, it would make life easier.
Thanks!
Link copied
