Spot elevation : Wittness line control
XXalessio.amodioXX
XXalessio.amodioXX
Hi all,
I would like to know if it is possible to create such a spot elevation.
If i will uncheck Leader form spot elevation type i cannot drag it out from its host.
I enclose a pic to make myself clearer.
Any idea?
architect.bim
Hi! In that case I would suggest to use detail lines. And create spot elevation with leader unchecked.
Maxim Stepannikov | Architect, BIM Manager, Instructor
XXalessio.amodioXX
little suggestion.
In order to not see the line, after locking the line to desire element, I chage its lenght to 1mm.
architect.bim
Sure! I do the same! I thought you need dashed line to be displayed. If not - short line is really what you need!
