spot elevation snaps - how to turn off for topo?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is it possible to turn off spot elevation snaps for topography? When I'm adding or adjusting spot elevations for topo annotation on a site plan, spot elevations always jump to a topo point when it's gets within 1'-0" of a point. Same for either adding a new point or adjusting the location of an existing point.
Using SNAP OFF command doesn't work; Going into MANAGE>SNAPS SETTINGS and turning off all snaps doesn't work; spot elevation will still jump to a point when within 1'-0".
I've had this issue with every version of Revit 2013-2017 and can't find an answer. When I'm annotating retaining walls and need to label top and bottom of benches, I need to get right to the edge to get the exact elevation, and I can't get close enough without it jumping. And when it jumps, it usually goes to another point in elevation since on a vertical cut using Site Designer, there are more than one point stacked on top of each other.
