Spot elevation on stair landings
Message 1 of 18
I am trying to put a spot elevation on the stair landing in section. The spot elevation picks up the floor slab (see image below) however, will not pick up any point of the stair itself. Have tried different tags. The stair is a monolithic type created in sketch mode.
Thank you in advance.
Replies (17)
Message 2 of 18
Hi. try moving your pointer to horizontal edge and pick for the location of spot elevation.
Message 3 of 18
I am afraid that a stair created using Stair by Sketch cannot host elevation labels. Stair by Components (even after converted to Sketch) can but I assume you don't want to redo your stairs. A workaround is draw a reference plane at each landing and lock it to the landing.
Message 4 of 18
Alfredo_Medina
Is it not enough to put elevations at landings? For the risers, you have a note in the plans you already have a note that says "such risers at such height".
Message 5 of 18
Thanks for the help! I'll try your suggestions to get around it:)
Message 6 of 18
artejon
Stairs by sketch can host spot elevation out of the box, no need to add a reference plane.
Revit add-ins: CAD Purger (delete UNUSED and selected line patterns & line styles, find and delete CAD), Rooms To Spaces, Schedule Utilities (Calculated Values/Combined Parameters To Tags, reuse view filter rules in schedule filters), View Filter Manager at Revit Apps Store
Message 7 of 18
Hi Toad. What do you mean "stair created using Stair by Sketch cannot host elevation labels"? Sorry if I didn't get your point. Most of the time I create my stair using sketch and I can label the elevation view without creating reference plane.
Message 8 of 18
Can you place a spot elevation on the landing of this stair?
Message 9 of 18
Hi Toad, when I create stair here on my revit using sketch, I can place spot elevation. Is it because of the version? Because we are using here 2017.1 and urs is 2015. I can't place label on your modelSmiley Sad Please see the screencast.
Thanks.
Message 10 of 18
Hi Toad, now I can...dunno what happen. awhile ago cannot. See attachedSpot elevation.JPG
Message 11 of 18
Can you upload that file?
Message 12 of 18
I didn't save that one but I created a new one using default archi template and created stair by sketch. Here's the file.
Message 13 of 18
You did it in an elevation. Try to do it in a Section. That was what he was asking.
Message 14 of 18
Oh yeah...hahaha!!! I didn't notice the section part. Apology for that, my mistake...Smiley Sad
Message 15 of 18
Alfredo_Medina
I don't understand the conversation. I use Revit 2016. I made a test, and I can put spot elevations in section, in elevation, in stairs by sketch or by component. Is this different in 2017? If it is, why?
Message 16 of 18
There is a 2015 file I uploaded. See if you can put a spot elevation on a
landing in the section.
Message 17 of 18
Hi Alfredo. That's great if you can create spot elevation to the riser or landing of the stair in the section view. On my part, I can't. Dunno why and Toad got a workaround by putting reference plane. Can you please screencast if its ok...? Thanks.
Message 18 of 18
Alfredo_Medina
I tried again today, and now I see the issue that you guys were mentioning. The only way I can put spot elevations in a section view of a stair by sketch is if the railing is visible, which feels like a bad workaround, because for some reason Revit can put a spot elevation at the bottom of the post of the railing but not on the surface of the tread. Very strange.
