Spot Elevation for Massing/ Levels in Architectural Elevation View
saisreedhar.gf
Message 1 of 14
saisreedhar.gf
Greetings!
Is there a way to mark the Spot Elevations for Level differences in an Architectural Elevation / Building Facade?
I am currently marking as just plain text instead of a "smart" tag.Elevation with Levels.jpg
Replies (13)
Message 2 of 14
I don't know what you mean by this.  "mark the Spot Elevations for Level differences"?
Message 3 of 14
saisreedhar.gf
If you refer to the image in my original post, the facade has a vertical wall flushed/aligned with ±000 and then a part wall which is at +150mm and the next is at +300 and so on... Just to create some features in elevation treatment.
Not sure if "spot elevation" is the correct term to be used here.
Message 4 of 14
Ah, I get it.  Generally, we annotate popouts/niches in Elevation with a plus/minus symbol.
Looks like you are doing same.
FWIW: the "LVL" designation is a little confusing, though.  "LVL" is "Level" in my world.  Those numbers are NOT related to the Level.
Message 5 of 14
Yes.  You can place a spot elevation with the elevation base = relative, and choose the level that you want to reference.
Message 6 of 14
saisreedhar.gf
No. It can't be done with "relative" spot elevation tags as the "Relative Base" is only limited to horizontal levels in the project. [See image] So the marker will give levels perpendicular to these horizontal levels.
What I need is a level which is parallel to these horizontal project levels! (It would be cool if Revit could recognize a Reference Plane as "Relative Base" instead.)
Message 7 of 14
I see what you want now. You can create a face based generic family with an instance depth shared parameter, place each on the surface of a wall and stretch the depth to meet the base plane 0, then you can tag it to report the depth.
Message 8 of 14
Perhaps this screenshot will lend some "perspective"...
Then again, maybe it won't.
Cheers.
Message 9 of 14
saisreedhar.gf
Yes. This works! Did you use the Face based generic family tag as suggested by @ToanDN?
Message 10 of 14
...one more:
Message 11 of 14
What exactly is "working"?
Message 12 of 14
saisreedhar.gf
The tag associated with the figurine, shows the depth which I need to replicate on Walls in Architectural Elevation
Message 13 of 14
There is no "magic" here. It's user-defined Model Text. No different than a Text Annotation.  Think about it. What is the depth/distance in relationship to?  Answer: Whatever you choose it to be in relationship to.
Message 14 of 14
